UndefinedMan
Mistrz
Pomógł: 7 razy Dołączył: 30 Mar 2007 Posty: 154 Skąd: Nysa City
Wysłany: Sob 04 Kwi, 2009 14:36 Jak zrobić buforowanie VIDEO?
Witam, mam zdefiniowany odtwarzacz Video za pomocą kodu
| Kod: | onSelfEvent (load) {
loadfunc = function(what){
createEmptyMovieClip("watcher",1000);
container.loadMovie(what);
watcher.onEnterFrame = function(){
if(_parent.container._width > 10){
//--the following makes the playersize for the movie-------
_parent.containerbox._width = _parent.container._width+17;
_parent.containerbox._height = _parent.container._height+40;
_parent.stopButton._y = _parent.container._height+18;
_parent.stepBack._y = _parent.container._height+18;
_parent.playButton._y = _parent.container._height+18;
_parent.stepForward._y = _parent.container._height+18;
_parent.sliderControls._y = _parent.container._height+25;
delete watcher.onEnterFrame;
stepForward.onRollover = function(){
this.gotoAndStop(2);
stepForward.onRollout = function(){
this.gotoAndStop(1);
stepForward.onPress = function(){
this.gotoAndStop(3);
container.stop();
// container._visible = false;//delete this line if you want visibleplayback
this.onEnterFrame = function(){
_parent.container.skipFrameAndStop(10);//or use nextFrameAndStop(); for 1 Frame
stepForward.onRelease = function(){
// container._visible = true;//delete this line if you want visibleplayback
container.play();
delete this.onEnterFrame;
stepForward.onReleaseOutside = function(){
container.play();
stepBack.onRollover = function(){
stepBack.onRollout = function(){
stepBack.onPress = function(){
container.stop();
_parent.container.skipFrameAndStop(-5);//or prevFrameAndStop();
stepBack.onRelease = function(){
container.play();
stepBack.onReleaseOutside = function(){
container.play();
Film skonwertowany do SWF odpala button.
Odtwarzacz bardzo dobrze chodzi, jednak chciałbym aby podczas zatrzymania filmu wyświetliła sie informacja, że jest buforowanie. Teraz jest tak, że się zatrzymuje film, zbuforuje SWF i dalej leci, ale między czasie nie ma informacji że buforuje.
Prosiłbym o pomoc. |
