Wielkosc animacji
Alexi
Wysłany: Wto 28 Paź, 2008 11:41   Wielkosc animacji
Mam pytanie. Otoz mam animacje. I ona zawsze jest taka jak wielkosc strony nie wazne czy fire fox czy explorer. Tzn. Jesli zrobie strone na 5cm na 5cm to i animacja bedzie widoczna cala ale w wielkosci 5cm na 5cm. Co zrobic by wielkosc jej byla stala niezaleznie od zmian wielkosci okna przegladarki?? Bardzo prosze o pomoc.
^sl01k
Wysłany: Wto 28 Paź, 2008 17:27
onSelfEvent (load) {
    Stage.scaleMode = "noScale";
    Stage.align = "TL";}
w pierwszej scenie na dziendobry
Opcje pozycji (w przykladzie jest "TL" ...
" " (default): displays the Movie centered in the 'Movie' window. All edges might be cropped if the 'Movie' window is smaller than the Movie
"L" (left): aligns the Movie along the left edge of the 'Movie' window and crops the top, bottom, and right sides as necessary
"R" (right): aligns the Movie along the right edge of the 'Movie' window and crops the top, bottom, and left sides as necessary
"T" (top): aligns the Movie along the top edge of the 'Movie' window and crops the bottom, left, and right sides as necessary
"B" (bottom): aligns the Movie along the bottom edge of the 'Movie' window and crops the top, left, and right sides as necessary
"TL" (top left): aligns the Movie along the top and left edges of the 'Movie' window and crops the bottom and right sides as necessary
"TR" (top Right: aligns the Movie along the top and right edges of the 'Movie' window and crops the top and left sides as necessary
"BL" (bottom left): aligns the Movie along the bottom and left edges of the 'Movie' window and crops the top and right sides as necessary
"BR" (bottom right): aligns the Movie along the bottom and right edges of the 'Movie' window and crops the top and left sides as necessary.
mam 12 lat i dopiero się uczę
http://fachowo.co
Alexi
Wysłany: Wto 28 Paź, 2008 22:36
No powiem ze nie bardzo mi to dziala. opcje LOAD uznaje za blad w scrypcie.
onFrame (1) {{Stage.scaleMode = "noScale";
    Stage.align = "T";}
stop();}
Doszedlem do czegos takiego i juz nie zmienia wielkosci ale tez nie idzie wyswietlic calego poprzez scroll w przegladarce. Poptrzebuje jeszcze mozliwosci scrollu.
Kermit
Wysłany: Pią 31 Paź, 2008 23:11
   Moje WWW: www.tsi.f6.pl
a jakiego swisha uzywasz ? w tym kodzie jest blad. powinno byc:
onFrame(1){
    Stage.align = "T";
^sl01k
Wysłany: Sob 01 Lis, 2008 11:35
taki bład to niebład
a jesli chodzi o scroll to zalezy on od css'ow jezeli nic w nich niemasz to powninien sie sam zrobic... zalezy tez jak wkladasz plik w htmla...
tutaj masz raczej problem po stronie xhtml'a/css'ow
http://fachowo.co
