adobe photoshop cs3 beta
Wysłany: Pon 18 Gru, 2006 23:25   adobe photoshop cs3 beta
http://labs.adobe.com/technologies/photoshopcs3/
JuRgEn
Wysłany: Wto 19 Gru, 2006 14:21
   Moje WWW: www.wojas.org
Słyszałem właśnie że ma wyjść ale generalnie wyznaję prawo Murphego:
Jeżeli udoskonalasz coś dostatecznie długo - na pewno to zepsujesz ale ja i tak zostanę przy starej wersji (: .
Pzdr
http://66.249.93.104
Wysłany: Wto 19 Gru, 2006 14:25
jak dla mnie to jest po prostu szybszy (uruchamianie) i narzędzia i to z boku (np. layers) jest jakoś tak fajniej zrobione.
New Features
New features for the Photoshop CS3 beta include the following:
Non-destructive Smart Filters
Smart Filters are Photoshop filters that are applied non-destructively, and that remain live and re-editable. To apply a Smart Filter, select one or more layers and choose Filter->Convert for Smart Filters. The selected layer(s) will be converted to a Smart Object, to which you can apply filters non-destructively. Smart Filters appear as parameters under the layer to which they have been applied. Edit the Smart Filter mask to adjust the filter’s effects on different areas of the image. Note that any filter is treated as a Smart Filter when you apply it to a Smart Object.
Quick Selection Tool
The new Quick Selection Tool creates selections by painting the general area of interest. Photoshop CS3 analyzes the image to complete the selection automatically. To remove pixels from a selection, hold the Opt (Mac)/Alt (Win) key and paint. You'll find the Quick Selection tool in the same slot as the Lasso tool in the Tools palette.
Refine Edge
The new Refine Edge feature offers a simple, flexible way to modify the edge of any selection. Available via the Options bar or via the Select menu, the Refine Edge dialog lets you smooth, feather, contract or expand the current selection by using simple slider controls. Experiment with the Radius slider to select irregular or fuzzy edges.
Automatic layer alignment and blending
Using automatic layer alignment and blending, easily combine the best parts of multiple images of the same scene into one "best" image. Simply place multiple, related images on separate layers in one document, and let Photoshop CS3 analyze the contents, moving and rotating the layers so they overlap as precisely as possible. Then use the masking tools to reveal the areas you need from different layers to finalize the elements of the composite image. Automatic layer blending seamlessly blends the color and shading into the final image. The "Auto-Align Layers" and "Auto-Blend Layers" commands are both found in the Edit menu. Note that you must have multiple layers selected simultaneously in the Layers palette before you can apply these commands.
Vanishing Point with multiple, adjustable angle perspective planes
One of the most powerful new features of Photoshop CS2 is now even more flexible. Vanishing Point adjusts brush strokes, healing and cloning as you paint over its perspective planes. In Photoshop CS3, you are no longer restricted to adding planes at 90-degree angles. You can now quickly and easily create multiple planes in any image, connected at any angle. In addition, artwork (for example, a product label pasted from the clipboard) can be wrapped around multiple planes simultaneously. To adjust angles of planes, use the Alt/Option key when dragging on a side point of a plane, or enter a specific angle in the Angle field in the dialog.
Black and White conversion
Advanced black-and-white conversion is now simpler and faster. With the new Black and White adjustment, one button analyzes the image and offers conversion settings. Fine-tune your image with simple sliders that control the conversion of each color. Click and drag any portion of any image to adjust the corresponding tonal range (for example, click and drag on a red car to lighten or darken all red tones). The improved Channel Mixer adjustment includes new black-and-white presets, the ability to save your own settings as presets for reuse later, and the new Total indicator that keeps you informed on the total percentage contribution from all three color channels.
Enhanced Adobe Camera Raw
Camera Raw 4.0 now features Fill Light, Recovery, and Vibrance controls; a parametric tone curve; sophisticated black & white and split toning controls; and more.
ps. wow ale duże obrazki
greg801
Wysłany: Czw 21 Gru, 2006 09:04
witam
tez mam ta wersje testowa i musze powiedziec ze CS3 bardzo szybko sie uruchamia juz 3 sekundy to juz CS2 wymieka przy nim bo startuje 18 sekund
nugatt,
co to jest za czcionka ktora uzyles w tekscie?
Wysłany: Czw 21 Gru, 2006 11:58
>>> base 02 <<<
qncept
Grafik komputerowy.
Wysłany: Sob 06 Sty, 2007 19:29
Mi w zupełności starcza 7.0 a te nowe wodotryski to o kant d.... potłuc.
Przecież to wszystko można zrobić nawet na 6.0 ... ale dobrze, ze jest coś takiego jak Cs3 może niedługo wypuszczą Cs4 :P .
Pozdrawiam Wszystkich ...
moje projekty :
http://www.qncept.ovh.org
Seb
Wysłany: Sob 06 Sty, 2007 21:32
gdyby to był Twój post wklepałbym pomógł qnceptowi :wink:
hiiijaa i poczułem się super bo na 6.01 siedzę cały czas 8)
thx !spox
qncept
Grafik komputerowy.
Wysłany: Nie 07 Sty, 2007 23:04
Seb klepanie jest w modzie :) :P
moje projekty :
ptak12
Wysłany: Sob 16 Maj, 2015 12:02
Ja mam Phtoshopa C6 z polską wersją i nie trzeba mi jej ulepszać ;)
Queroels
Wysłany: Pią 15 Kwi, 2016 06:17
Również mam C6 i według mnie jest to najlepsza wersja tego programu, nic więcej w nim nie potrzeba.
Kolunie co tam? Pepsjusz tu jest
