full screan / cały ekran / na maxa ... jak ?? |
^sl01k
Wysłany: Wto 29 Sty, 2008 17:53
jest to taki gadżet jak na youtube, więc kiedyś natknąłem się na playera flv i do niego dołączony jest taki as
| Kod: |
* Display user interface management of the players MCV pattern.
* @author Jeroen Wijering
* @version 1.6
import com.jeroenwijering.players.*;
import com.jeroenwijering.utils.*;
class com.jeroenwijering.players.DisplayView extends AbstractView {
/** reference to the imageloader object **/
private var imageLoader:ImageLoader;
/** Reference to the currently active item **/
private var currentItem;
private var itemSize:Array;
private var thumbSize:Array;
/** Starting position of the players **/
private var startPos:Array;
/** Constructor **/
function DisplayView(ctr:AbstractController,cfg:Object,fed:Object) {
super(ctr,cfg,fed);
Stage.addListener(this);
itemSize = new Array(config['displaywidth'],config['displayheight']);
thumbSize = new Array(config['displaywidth'],config['displayheight']);
var ref = this;
var tgt = config["clip"];
imageLoader = new ImageLoader(tgt.display.thumb);
imageLoader.onLoadFinished = function() {
ref.thumbSize = new Array(this.targetClip._width,
this.targetClip._height);
ref.scaleClip(tgt.display.thumb,this.targetClip._width,
startPos = new Array(tgt._x,tgt._y);
setColorsClicks();
setDimensions();
/** Sets up colors and clicks of all display items. **/
private function setColorsClicks() {
var ref = this;
// background
var tgt = config["clip"].back;
tgt.col = new Color(tgt);
tgt.col.setRGB(config["backcolor"]);
// display items
var tgt = config["clip"].display;
tgt.setMask(config["clip"].mask);
if(config["showicons"] == "false") {
tgt.playicon._visible = false;
tgt.activity._visible = false;
tgt.back.tabEnabled = false;
if(config["linkfromdisplay"] == "true") {
tgt.back.onRelease = function() {
ref.sendEvent("getlink",ref.currentItem);
} else {
ref.sendEvent("playpause");
if(config["logo"] != "undefined") {
var lll = new ImageLoader(tgt.logo,"none");
lll.onLoadFinished = function() {
tgt.logo._x = ref.config["displaywidth"] -
tgt.logo._width - 10;
tgt.logo._y = ref.config["displayheight"] -
tgt.logo._height - 10;
lll.loadImage(config["logo"]);
tgt.logo.onRelease = function() {
/** Sets up dimensions of all controlbar items. **/
private function setDimensions() {
if(Stage["displayState"] == "fullScreen") {
config["clip"]._x = config["clip"]._y = 0;
tgt._width = Stage.width;
tgt._height = Stage.height;
} else {
config["clip"]._x = startPos[0];
config["clip"]._y = startPos[1];
tgt._width = config["width"];
tgt._height = config["height"];
if(config["displayheight"] >= config["height"] -
config['controlbar'] && config["displaywidth"] ==
config["width"]) { tgt._height--; }
scaleClip(tgt.thumb,thumbSize[0],thumbSize[1]);
scaleClip(tgt.image,itemSize[0],itemSize[1]);
scaleClip(tgt.video,itemSize[0],itemSize[1]);
config["clip"].mask._width =
tgt.back._width = Stage.width;
config["clip"].mask._height =
tgt.back._height = Stage.height;
} else {
tgt.back._width = config["displaywidth"];
tgt.back._height = config["displayheight"];
tgt.playicon._x = tgt.activity._x = Math.round(tgt.back._width/2);
tgt.playicon._y = tgt.activity._y = Math.round(tgt.back._height/2);
tgt.playicon._xscale = tgt.playicon._yscale =
tgt.activity._xscale = tgt.activity._yscale =
tgt.logo._xscale = tgt.logo._yscale = 200;
tgt.logo._x = Stage.width - tgt.logo._width - 20;
tgt.logo._y = Stage.height - tgt.logo._height - 20;
} else {
if(config["largecontrols"] == "true") {
tgt.activity._xscale = tgt.activity._yscale = 200;
} else {
tgt.logo._xscale = tgt.logo._yscale = 100;
if(tgt.logo._height > 1) {
tgt.logo._x= config["displaywidth"]-tgt.logo._width -10;
tgt.logo._y= config["displayheight"]-tgt.logo._height-10;
/** Show and hide the play/pause button and show activity icon **/
private function setState(stt:Number) {
switch(stt) {
case 0:
if (config["linkfromdisplay"] == "false" &&
config["showicons"] == "true") {
tgt.playicon._visible = true;
break;
case 1:
if (config["showicons"] == "true") {
tgt.activity._visible = true;
break;
case 2:
break;
/** save size information and rescale accordingly **/
private function setSize(wid:Number,hei:Number) {
itemSize = new Array (wid,hei);
/** Scale movie according to overstretch setting **/
private function scaleClip(tgt:MovieClip,wid:Number,hei:Number):Void {
var tcf = tgt.mc._currentframe;
tgt.mc.gotoAndStop(1);
var stw:Number = Stage.width;
var sth:Number = Stage.height;
} else {
var stw = config["displaywidth"];
var sth = config["displayheight"];
var xsr:Number = stw/wid;
var ysr:Number = sth/hei;
if (xsr < ysr && config["overstretch"] == "false" ||
ysr < xsr && config["overstretch"] == "true") {
tgt._width = wid*xsr;
tgt._height = hei*xsr;
} else if(config["overstretch"] == "none") {
tgt._width = wid;
tgt._height = hei;
} else if (config["overstretch"] == "fit") {
tgt._width = stw;
tgt._height = sth;
} else {
tgt._width = wid*ysr;
tgt._height = hei*ysr;
tgt._x = stw/2 - tgt._width/2;
tgt._y = sth/2 - tgt._height/2;
tgt.mc.gotoAndPlay(tcf);
/** Load Thumbnail image if available. **/
private function setItem(idx:Number) {
currentItem = idx;
if(feeder.feed[idx]["image"] == "undefined") {
tgt.thumb.clear();
tgt.thumb._visible = false;
} else {
imageLoader.loadImage(feeder.feed[idx]["image"]);
tgt.thumb._visible = true;
/** OnResize Handler: catches stage resizing **/
public function onResize() {
if(_root.displayheight > config["height"]+10) {
config["height"] = config["displayheight"] = Stage.height;
config["width"] = config["displaywidth"] = Stage.width;
setDimensions();
/** Catches fullscreen escape **/
public function onFullScreen(fs:Boolean) {
if(fs == false) { setDimensions(); }
a tu cała dokumentacja http://www.jeroenwijering...r#documentation |
| Ostatnio zmieniony przez mielu Wto 29 Sty, 2008 17:58, w całości zmieniany 1 raz |
^sl01k
Wysłany: Wto 29 Sty, 2008 17:59
jak CI się uda to podziel się tym na forum |
^sl01k
Wysłany: Wto 29 Sty, 2008 18:04
w tym momencie tego niepotrzebuje ale za tydzien do tego siade...
zazwyczaj na odpowiedz na tym forum troche sie czeka niespodziewalem sietak szybkiej reakcji ... i to celnej ... z tego co wyczytalem powinno dac sie to skleic z swishem ...
I LOVE JS |
http://fachowo.co |
Grzesiek82
Pomógł: 19 razy Wiek: 43 Dołączył: 08 Maj 2007 Posty: 101 Skąd: Kolbuszowa
Wysłany: Wto 05 Lut, 2008 15:07
^mielu z tym skryptem trochę zaszalałeś hehe mam coś prostszego
a wiec tak w kodzie html wrzucamy takie coś:
| Kod: | | allowFullScreen="true" |
a w swishmaxie takie coś:
| Kod: | Stage["displayState"] = "fullScreen"; //dla pełnego ekranu
Stage["displayState"] = "normal"; // powrót do normalnego widoku
jeszcze jedna informacja do w/w skryptów, działają one jedynie w 9 i wyższych wersjach Flash Playera |
_________________ Wyobraźnia jest ważniejsza od wiedzy, ponieważ wiedza jest ograniczona. - Albert Einstein |
| Ostatnio zmieniony przez Grzesiek82 Wto 05 Lut, 2008 16:00, w całości zmieniany 3 razy |
Wysłany: Wto 05 Lut, 2008 15:33
| Grzesiek82 napisał/a: | mielu z tym skryptem trochę zaszalałeś hehe mam coś prostszego |
troszkę |
^sl01k
marcino
Mistrz
Pomógł: 10 razy Wiek: 39 Dołączył: 21 Sie 2007 Posty: 159 Skąd: Bytów
Wysłany: Wto 05 Lut, 2008 19:33
witam,
extra bajer
a jak zrobić żeby jeszcze nie skalował animacji ?
pozdrawiam. |
^sl01k
Grzesiek82
Wysłany: Wto 05 Lut, 2008 19:52
lub
| Kod: | | fscommand("AllowScale","false"); |
mro
Wysłany: Pią 08 Lut, 2008 14:27
a ja mam pytanie czy ten full screen działa wam pod IE bo mi nie....
może jakaś rada??
ps. jak usunąć suwaki w firefoxie?? da się wogóle? |
Grzesiek82
Wysłany: Pią 08 Lut, 2008 14:50
| mro napisał/a: | | a ja mam pytanie czy ten full screen działa wam pod IE bo mi nie.... | u mnie w IE7 działa z tym, że zanim uruchomię flasha na stronie wyskakuje belka z informacja o pozwolenie na wykonanie java scriptu lub kontrolek ActiveX | mro napisał/a: | | ps. jak usunąć suwaki w firefoxie?? da się wogóle? | o jakie suwaki ci chodzi ? |
mro
Wysłany: Pią 08 Lut, 2008 14:53
| suwaki strony html pod ie znikneły ale w ff nie :/ |
Piotr
Pomógł: 19 razy Dołączył: 28 Sty 2005 Posty: 252
Wysłany: Nie 21 Mar, 2010 10:25
No i poległem (od zawsze nie lubiałem html'a), czy ktoś będzie łaskaw "łopatologicznie" wskazać mi miejsce gdzie mam wpisać ten kawałek kodu | Kod: | | allowFullScreen="true" | w poniższy fragment ?
| Kod: | <body>
<div id="flashcontent">
<div id="content">
</div>
<div id="top">
Do poprawnego działania tej strony wymagana jest wtyczka Adobe Flash Player oraz włączona obsługa
JavaScript.
<br />
<a class="link" href="http://www.adobe.com/go/getflash/">Pobierz wtyczkę</a>
<br />
<br />
This site requires Adobe Flash Player and JavaScript in your browser.
<br />
<a class="link" href="http://www.adobe.com/go/getflash/">Get Flash Player</a>
</div>
</div>
<script type="text/javascript">
var so = new SWFObject("main.swf", "100%", "100%", "6", "#000000");
so.addParam("scale", "noscale");
so.write("flashcontent");
</script>
</body> |
Pozdrawiam ... |
Wysłany: Nie 21 Mar, 2010 12:07
To nie html tylko jakieś byle java Swfobiekt, czy coś takiego ....
| Cytat: | | so.addParam("scale", "noscale") |
Tak na chłopski rozum, bo się nei znam na objektach jawowych - te, to NoScale może warto na fullscreen?
a może
dodaj kolejną linię, którą zapewne napisałem błędnie, bo nie znam się, jednak sens powinieneś pojąć:
| Cytat: | | so.addparam("allowFullScreen", "true") |
